Hard to get in neutral while running - Suzuki GSX-R Motorcycle Forums Gixxer.com
 3Likes
  • 2 Post By oldgixxer
  • 1 Post By SlingshotAndy
post #1 of 5 (permalink) Old 04-20-2017, 05:47 AM Thread Starter
I have a 1986 GSXR750, while running it almost impossible to get into neutral. From first it will pop straight into second, while the engine is off it's about normal getting it into neutral? Is this an adjustment issue?
Michael Fuller is offline
post #2 of 5 (permalink) Old 04-20-2017, 07:21 AM
Berdy's Avatar
Re: Hard to get in neutral while running
You can try adjusting your clutch cable. My K7 600 was the same way though, I found it easier to go from 2nd to N by slightly tapping on the shifter lol.
Berdy is offline
post #3 of 5 (permalink) Old 04-20-2017, 07:32 AM
1st Gen 750 has hydraulic clutch,there is no cable to adjust. Your K7 600 is irrelevant in the oil-cooled forum
That being said,I'd have a look at the basket/hub for notches/grooves which would cause the plates to hang up,causing issues finding neutral,etc
Geesxara and TJS like this.
post #4 of 5 (permalink) Old 04-20-2017, 02:17 PM
It could be as simple as needing to bleed the clutch hydraulics. Air will stop the clutch releasing fully, causing drag.
Geesxara likes this.
SlingshotAndy is offline
post #5 of 5 (permalink) Old 04-23-2017, 08:46 AM
On The Outside Looking In
THE SRADIATOR's Avatar
Motorcycle: THE SRADIATOR
Aftermarket clutches (cough...cough...Barnett...cough) are notorious for this due to their extra grippy nature.
Sometimes a slight back/forth rocking motion will help find neutral.
Otherwise a small, though annoying, price to pay for the extra performance they provide.
Another method is to seek neutral while rolling to a stop though not yet fully stopped.
THE SRADIATOR is offline
