1989 GSXR 1100 ground up rebuild - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 8 (permalink) Old 12-18-2012, 02:25 PM Thread Starter
Motorcycle: 1989 GSX-R1100 Basketcase, currently rebuilding from ground up. Bought from original owner for 250$
I have a 1989 GSXR 1100 that i bought for 250$. The drawback was that it was in pieces....several pieces. I bought this bike because i love it and i wanted a decent project. i have all the parts (Plastics, rolling chassis, motor etc...). I cleaned all the plastics and removed everything from the rolling chassis so i could take inventory of what i need to replace. I am waiting on breaking down the frame until i can get the motor finished. I have followed both the Suzuki Service Manual and the Haynes Repair Manual.
I have been taking my time in disassembling and labeling and bagging practically everything on the motor. I haven't run into any major problems ie..no broken/stripped bolts, no cracks <knock on wood>.
I am stuck at splitting the crankcase though. I can hear that parts of the split have separated when i tap it with a rubber mallet, but some part of it is still binding. I think it is in the recessed corner around the transmission output shaft.
Any thoughts on if i am missing anything, or tips on how to split a case thats nearly 25 years old?
Pictures available if necessary.
89Basketcase is offline
post #2 of 8 (permalink) Old 12-18-2012, 04:54 PM
gixerhp's Avatar
Motorcycle: Hayabusa
Re: 1989 GSXR 1100 ground up rebuild
Do you have the case bolt that is inside the generator hole?
gixerhp is offline
post #3 of 8 (permalink) Old 12-18-2012, 05:29 PM Thread Starter
If you are asking about the signal generator, then there was one bolt holding the rotor and then 3 bolts holding the stator, and all of those have been removed.
post #4 of 8 (permalink) Old 12-18-2012, 05:42 PM
Motorcycle: 1986 GSXR750
He means the alternator, from another thread:
" There is another well hidden bolt from the top. On the alternator mount housing there is a plug, under that plug is the hidden bolt. "
There is a few ninja bolts, but if you take your time you can find 'em all.
FruitLooPs is offline
post #5 of 8 (permalink) Old 12-18-2012, 05:42 PM
Motorcycle: 2008 Suzuki DRZ SM, 1987 YSR 50, SDG pitbike, kids dirtbikes
Welcome to GDC, get your red r than you can buy/sell in the classifieds and much, much more.
wicked86gsxr is offline
post #6 of 8 (permalink) Old 12-18-2012, 05:45 PM
image of an 88 750 motor showing some bolts from a previous thread, also mentions under oil filter etc. 1100 should be very similar.
post #7 of 8 (permalink) Old 12-19-2012, 11:14 AM Thread Starter
Found all those ninja bolts previously. i did find one that i missed though. It was attached to the oil return tube in the oil pan. I don't remember the manual stating anything about removing that one.
I split the case and bagged the trans, trans cam, forks, and oil pump. the only thing left in the case is a couple of the dowels and the two bearings from the transmission.
Everything is in great condition, no chips, no shavings, even the bearings roll without any grit.
post #8 of 8 (permalink) Old 12-19-2012, 12:46 PM
Motorcycle: CB 500 ´96, GSXR 1100 ´89
sensational m8. im following you now.
check out the transmission shaft bearings btw. I completely overhauled the engine due to a second gear that popped out and one of those bearings was with its intestines out. no need to say that new ones will be installed...
cheers¡¡
CHEMOTO is offline
