89-90 750-1100 Frame Differences - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 10 (permalink) Old 11-12-2012, 08:31 AM Thread Starter
Motorcycle: Life Behind Bars
OK. So growing up in the 80's I have always had a 1st gen bike. But lately I have been getting into the 2nd gen bikes.
What are the differences between the 750 and 1100 for 89-90?
School me.
tonyc9928 is offline
post #2 of 10 (permalink) Old 11-12-2012, 09:53 AM
Motorcycle: 86 7/11 86 1100 87 1100 89 750 95 xr650l 86 ATC 125m
Re: 89-90 750-1100 Frame Differences
The 90 750 frame is a bit taller , so its the best for 7/11. You don't need engine removal for valve adjustment.
89-90 1100 and 90 750 frames may be the same but , they also may have different head angle.
Ghost probably knows.
rodriguez is offline
post #3 of 10 (permalink) Old 11-12-2012, 10:47 AM
Intguy's Avatar
Motorcycle: 1997 ZX11 Ninja
The 90 1100 frames are definately taller than the 750, that much I know.
cheers
Intguy is offline
post #4 of 10 (permalink) Old 11-12-2012, 10:52 AM Thread Starter
I have 3 now. 2 are deff 750 frames but they are a little different. One has bolts that hold the tank bumpers and the other does not have any bolts, they just glue on. The sub frames are slightly different too. One has more bolt holes and brackets.
The other frame I do not know if it is a 750 or 1100 frame. There are no Vin numbers on the head tube and they have not been removed.
post #5 of 10 (permalink) Old 11-12-2012, 11:03 AM
Intguy's Avatar
I think the lower engine mount has a larger hole on the 1100.
cheers
Intguy is offline
post #6 of 10 (permalink) Old 11-12-2012, 11:57 AM
jpnjim's Avatar
Motorcycle: GSXR1100J in progress, neglected GSXR1100H & ex-racer GSXR750G in pieces
Relaxed steering geometry in 1990 750 to fit the curved cooler.
I think the 1990 frame gained some weight too,
but just relying on (flawed) memory for that
jpnjim is offline
post #7 of 10 (permalink) Old 11-12-2012, 12:51 PM
Ghostrider
ghostrider.1127's Avatar
Motorcycle: few gsx-r
88-89 is the little
90-91 looks like an 11 (89-92) but its also different few mm low
tank rubber
750 88-89 glued
750 91-(92 IN US) bolteed
89-90 1100 glued
91-92 1100 bolted
top mount shock
all 750 AND 1100 89 bolted
other fusion
mount point steering damper
750-88-89 dosen t match oem 750 90-91 parts cause two hole are more in front respect other slighy frame
different steering geometry between 750 88-89 and 750 90 and 750 91-92 and 1100 89-90 and 1100 91-92
bracket for oil cooler are l#different on 750 88-89 frame
like on top is different (not spacing between hole) mount
ghostrider.1127 is offline
post #8 of 10 (permalink) Old 11-12-2012, 04:25 PM
Intguy's Avatar
Originally Posted by ghostrider.1127 View Post
88-89 is the little
tank rubber
750 88-89 glued
89-90 1100 glued
91-92 1100 bolted
top mount shock
other fusion
That's some good intel right there!
cheers
Intguy is offline
post #9 of 10 (permalink) Old 11-12-2012, 06:53 PM
I told you guys. Ghost is like the GSXR encyclopedia.
post #10 of 10 (permalink) Old 11-13-2012, 06:54 AM
Ghostrider
and there are more diff on rear subframe between single light model and double
