750 m swingarm spacer - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 3 (permalink) Old 11-04-2012, 10:21 AM Thread Starter
Have purchased 2000 srad braced swing arm that comes complete with pivot spindle spacer but need slingshot spacer to fit inside srad item.
Would it be cheaper to buy second hand arm complete or should I order new from suzuki?
Will spacer from all models with 20mm spindle fit?
jarvis is offline
post #2 of 3 (permalink) Old 11-04-2012, 02:30 PM
Re: 750 m swingarm spacer
New internal spacers from Suzuki are usually not much money but you really ought to do some measuring to see what you need.
JR
javadog is offline
post #3 of 3 (permalink) Old 11-04-2012, 03:17 PM Thread Starter
JR
Thanks, from other posts it seems the standard Slingshot sleeve should slide inside the srad spacer which is OK if you actually started with the original item. Just want the cheapest option be it buy just the part or a whole swingarm
jarvis is offline
