Got my new track weapon. Old school Power! - Page 4 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #61 of 69 (permalink) Old 09-30-2012, 11:27 AM
tonyc9928's Avatar
Motorcycle: Life Behind Bars
Re: Got my new track weapon. Old school Power!
Build is looking TiTs!!
I had a problem getting my one piece lowers on my 1100. I ended up putting them on first then adjusting everything else to match them.
Are they one or two piece lowers?
Keep trying. I wanna see this bike all together.
tonyc9928 is offline
post #62 of 69 (permalink) Old 09-30-2012, 01:08 PM
awasson's Avatar
Motorcycle: 1985 GSXR 750, 1986 GSXR Limited, GSXR750RK (in restoration mode), 1973 GT-750 (no longer have, looking for another)
Originally Posted by Oldschoolfool711 View Post
The back wheel failed big time. Damage to the sprocket carrier So wheels will go up for sale. Shop said they made a spacer. I didnt see one after the damage was done. The wheel didnt lock up but did cause outer brake pad to wear down and fail. For quick fix im putting 5.5 91 gsxr wheels and inverts.
What happened to the wheels and can the rear be repaired? I think they look way better than any 2nd gen wheels. What are they?
awasson is offline
post #63 of 69 (permalink) Old 10-06-2012, 12:13 AM
tonyc9928's Avatar
PVM's I think?
post #64 of 69 (permalink) Old 10-06-2012, 12:37 AM
Superstock
Nope... OSF was using a classic set of Dymags.
jb_xx
jackbird_xx is offline
post #65 of 69 (permalink) Old 10-06-2012, 11:06 PM Thread Starter
Oldschoolfool711's Avatar
Well for me, I had to go with the quick fix. I had set extra fresh powder coated white wheels. With tires. So on it went. I dont want to have to take the tire off and get it repaired then painted again and tire mounted. The sprocket carrier will have to get a new sprocket as it wobbles on the carrier. I will swap out old front end for inverts and hayabusa 6 piston calipers. I have a black fender to go on the bike. Now its looking like the vance haines race bike. Motor turned out not to be big built motor as seller told me. I know how built motor feels. I do know a port job took place but all the other stuff is not there. Plenty of power the motor only has 5k miles on it and shifts flawlessly.
Oldschoolfool711 is offline
post #66 of 69 (permalink) Old 11-14-2012, 09:32 PM Thread Starter
So here it is, track ready for battle. Gonna try to make to Dec 3 Chuckawalla ride with MMarsh. Yes those Dymag got some damage to the back wheel so off they went. I can fix them but have to strip off the powder coat and weld repair so off to the auction block they go. I need other things for my other build anyways. I dont have time to do more repairs and who knows if the welds will hold? So I threw on the 1100 forks set up by Race Tech good seals. Yoshimura tirple clamp. Graves clip ons. I personally think the bike looks better now than with the 18 black wheels. I have wider tires and better selection. The brakes are awesome. The seals where busted on the black forks anyways which would of been more time and money. I was unable to get the lowers on there but will fiddle with them later to see why they are not fitting. I have oem mids and lowers. The upper is from the DUDE as you can see in the picture the mids sit on the frame a little high. I un did the middle screw and pull it down some and still not enough clearance for the yosh headers. really wanted to see full fairing bike. I rode it up the street pulls real solid. Only 5k miles on the motor so it shifts tight. It has a port job but doubt the engine is 1255 built motor. Still plenty fast. Yosh pipe sounds great. Lots off back firing from the 38 mm smooth bores. Cant wait to take it out and whomp on it. Im going up 47 tooth in back.
post #67 of 69 (permalink) Old 11-15-2012, 01:38 AM
awasson's Avatar
Looks great... Too bad about the Dymags but the 17's look great anyway.
What windshield is that? It doesn't look like a Zero Gravity... Is that one of the Chinese ones?
awasson is offline
post #68 of 69 (permalink) Old 11-15-2012, 01:19 PM
hd53's Avatar
Motorcycle: too many Suzuki's GS/GSX-R(R), Bimota SB6, Mount Everest Pile Of Parts
Going to go meet a guy to buy a nice oil cooler for my Blue thunder build! Hans yep thats the bike I got my idea off of. I changed the tank scheme to my own style to fit the bikes lines in the back. I want to see how 18inch wheels will feel in the turns with those skinny tires. Get out and ride its Sunday!
few more shots of Eriks creations ...
hd53 is offline
post #69 of 69 (permalink) Old 11-15-2012, 10:13 PM Thread Starter
Nice set of RGs right there. I like the one to the right better.
