1052 vs. 1127 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 14 (permalink) Old 12-28-2011, 04:53 PM Thread Starter
Motorcycle: 1987 gsxr 1100 custom chromolly frame,
1052 vs. 1127
I'm sure this info has been covered on here at some point but not having much luck locating it . I know that 1127 blocks and cranks won't interchange with 1052's (without machining) but what about the head? From what I understand 1990 is a pre-shim era head. Will a 1990 head be compatible on a 1052?
Thank you,
Trent
Hillclimbing an 1166 in a modified CR 500 chassis.
dirtgixxer is offline
post #2 of 14 (permalink) Old 12-28-2011, 08:10 PM
Motorcycle: mike91 1216
Re: 1052 vs. 1127
a 1127 block,crank and head WILL work in 1052 cases
YES a 90 head will bolt on
mike91 1216 is offline
post #3 of 14 (permalink) Old 12-28-2011, 08:29 PM
The other OG
old gsxr's Avatar
Re: 1052 vs. 1127
so a dot head doesn't fit a 1052, but fit's a 1127 i don't think from past discussions
a 1127 head fits on 1052 barrels
old gsxr is offline
post #4 of 14 (permalink) Old 12-28-2011, 08:50 PM Thread Starter
Re: 1052 vs. 1127
Thank you both! I had the opportunity to pick up a 1990 1100, but already having (3 ) 1052's I wanted the option to put the 1127 head on my 1052 cylinders if needed. I will stick with searching for the 86-88 models.
post #5 of 14 (permalink) Old 12-28-2011, 09:05 PM
Re: 1052 vs. 1127
Why won't a dot head fit a 1052??
post #6 of 14 (permalink) Old 12-28-2011, 09:08 PM Thread Starter
Re: 1052 vs. 1127
Are the 1052 and 1990 1127 physically the same size? as far as motormounts and such?
thank you,
post #7 of 14 (permalink) Old 12-28-2011, 09:18 PM
Re: 1052 vs. 1127
The only difference in 1052 vs 1127 cases is a 30mm starter hole vs a40mm on. And the case covers are a bit different
They both will mount up in any oil cooled chassis 85-92
This is what Im aware of and have played with
post #8 of 14 (permalink) Old 12-28-2011, 09:27 PM
Re: 1052 vs. 1127
Holes for sleeves might be a bit different. Never measured
post #9 of 14 (permalink) Old 12-28-2011, 09:47 PM
Re: 1052 vs. 1127
The motor I have in my now is
1127 cases and crank
Big block off my 1052
With a dot head
So that there is fact not hearsay
post #10 of 14 (permalink) Old 12-28-2011, 10:03 PM Thread Starter
Re: 1052 vs. 1127
Thanks Mike, I think I will buy that bike, I just need the engine for my hillclimber. But wanted to know mor about those 1127's. could you shed some light on dot head, never heard one referred to that way
thanks
post #11 of 14 (permalink) Old 12-28-2011, 10:11 PM
Re: 1052 vs. 1127
Use the search box
Dot head
It's been discussed many many times
post #12 of 14 (permalink) Old 12-28-2011, 10:33 PM
The other OG
old gsxr's Avatar
Re: 1052 vs. 1127
With a dot head
Well you just made my day Mike , i have 3 dot heads -1 spare that will go on my 88 -1100 along with 38mm flatsides and yoshi cams
i can remember something about the cam chain tunnel front or back that was suposed to be different
old gsxr is offline
post #13 of 14 (permalink) Old 12-28-2011, 10:55 PM Thread Starter
Re: 1052 vs. 1127
Sure didn't intend for everyone to answer this common question, but I just did't have time to research this site. The guy needed an answer from me asap or was going to sell to someone else. Thanks.
post #14 of 14 (permalink) Old 12-28-2011, 10:56 PM
Re: 1052 vs. 1127
Keep in mind. The dot head will work bolt on with stock pistons
Any big bore domed style piston, the chambers and the pistons will both need modded
Not just a quick switcharoo
