opting not to drill slides- dynojet???? - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 14 (permalink) Old 05-03-2010, 09:26 PM Thread Starter
92gixxer's Avatar
Motorcycle: 2005 Buell XB12R-back with my first love: V2!
In the dynojet kit it states to drill and tap the slides and insert these little plastic threaded restrictors in the tapped holes. It also states that for "track or hard street use the holes may be left stock". In my particular kit, there are 2 plastic restrictors that don't have holes in them and 2 that do???? is this right? If I choose not to drill the slides and not put in the restrictors what kind of headache am I setting myself up for, if any? Anyone have some insight/ experience in this?
92gixxer is offline
post #2 of 14 (permalink) Old 05-03-2010, 09:54 PM
Re: opting not to drill slides- dynojet????
The size of the holes affects the rate of rise of the slides. If it were me, I'd call Dynojet and get them to talk to you a little about your specific application.
JR
javadog is offline
post #3 of 14 (permalink) Old 05-04-2010, 01:45 AM
Motorcycle: 87 GSXR 7/1216
give it a shot. the worst that will happen is you might have a flat spot here or there. With this kind of CV carb, the rate of slide lift controls the amount of accel enrichment you get, that's why there is no accelerator pump. So by changing the slide lift speed you're changing the 'size' of the accel pump hit, faster = leaner but the engine can rev up faster. Slower = richer but the engine might bog or accelerate slowly.
Like everything else it's a tradeoff. Me personally I would give it a shot without drilling them. You could also call Dynojet but don't expect to get an especially helpful answer.
Factory pro, incidentally, leaves the slides stock but tailors the speed with a different spring.
Gives you something to think about - if you have a spare set of springs you could stretch them for more preload or cut them down to get different slide opening/enrichment curves.
good luck...
robertob is offline
post #4 of 14 (permalink) Old 05-04-2010, 02:48 AM
Motorcycle: some gsx-r
good luck...
In My opinion:
1) Is better don't stretch springs for more preload: isn't easy to stretch 4 springs at the same rate (eventually you can cut them at the same rate).If you need spring strongest.. you have to buy others..2)
2) about the sliders: If you drill the holes they become faster, and I think you enrich the mixture, because you open completely the main jet at the bottom of the carb earlier.
fulviogsx is offline
post #5 of 14 (permalink) Old 05-04-2010, 06:57 AM Thread Starter
92gixxer's Avatar
Yeah, I understand how the hole size affects the slide lift rate. W/ the Dynojet kit the little plastic inserts they give you have a smaller hole than stock meaning they want a slower lift rate?? I may give it a try w/o drilling first and see how it acts. Hopefully i won't end up w/ a flat spot. I may also have to give Dynojet a call and ask why I have 2 POS inserts w/ no hole in them.
92gixxer is offline
post #6 of 14 (permalink) Old 05-04-2010, 06:01 PM
nikos1400's Avatar
Motorcycle: GSXR750L
good luck...
Good carb info.
Pieces like this could be added somehow to the "Carb sticky".
nikos1400 is offline
post #7 of 14 (permalink) Old 05-05-2010, 02:36 AM
Originally Posted by nikos1400 View Post
Good carb info.
man take care : is the opposite.
needle up:rich
needple down: lean
Therefore:
slide faster (big holes): enrich
slide slower (small holes): leaner
post #8 of 14 (permalink) Old 05-05-2010, 06:21 AM
idiot
mark_E's Avatar
Motorcycle: 1990 GSXR1100
who else got springs in their fp kits? . . . 'cause i didn't!!!
mark_E is offline
post #9 of 14 (permalink) Old 05-05-2010, 12:44 PM
needle up:rich
needple down: lean
Therefore:
Yes I agree but you are forgetting that the holes affect TRANSITION, not steady. With changes to the springs you are absolutely correct. With changes to the holes it is opposite because you're just adjusting the speed of lift not the amount.
robertob is offline
post #10 of 14 (permalink) Old 05-05-2010, 12:45 PM
For bandit 1200, sorry I just assumed it was for all. Must depend on the kit.
robertob is offline
post #11 of 14 (permalink) Old 05-05-2010, 12:53 PM
In My opinion:
You are right about the springs for sure. But on #2 think about it - the slide rises to a certain level depending on the vacuum differential between the back and front of the slide. This determines needle position and richness. This modifies enrichment for engine load.
HOWEVER, the slide POSITION does not change with bigger or smaller holes. Only the rate of change of position. So it only affects transitions (getting on the throttle during accel), not steady state (like full throttle). The slower it rises, the more vacuum is at the main jet (like a choke) so the richer.
The SPRING changes slide position by the way, but the holes do not.
robertob is offline
post #12 of 14 (permalink) Old 05-05-2010, 01:01 PM
jakegsxr11's Avatar
Motorcycle: 1992 GSXR 1100 / 89 GSXR 750
I didn't get springs in my FP kit
jakegsxr11 is offline
post #13 of 14 (permalink) Old 05-05-2010, 01:01 PM
oh yeah also what happens when you remove the airbox is you increase the pressure differential (delta P) between the mouth of the carb and the engine, so the slide will rise faster anyway. That may be why dynojet slows it down.
robertob is offline
post #14 of 14 (permalink) Old 05-05-2010, 02:27 PM
Motorcycle: 88 GSXR750, RZ350, 200XCW, TZ250, DR650
No springs with my fp kit
nokturnal is offline
