Cammotion / Yoshimura Cam Specs ? - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 6 (permalink) Old 02-29-2004, 07:26 AM Thread Starter
Streetfighting Monster
UK lee's Avatar
Motorcycle: GSXR1340 Yoshifighter , GSXR 1000 K6
Yo Dudes
I'm after some info regarding Cam Motion G21X and the Yoshimura 'Stg 2' SURX162 cams for the Oil cooled GSXR engine
Does anyone know the 'specs' of these cams ? The numbers i'm after are ;
Max. valve lift
Duration
Lobe centre angles
Or any other info regarding these particlular grinds .
Even better , has anyone had any actual experience of either ( or both ! ) of these cams ?
What kind of power / torque did they give in your application ? ( and what was it ?)
How would you compare them to other performance cams ( or the stock ones !)
What LCA's did you time them in at & with what results ?
have you got any other comments regarding these particular cams ?
Any info you cloud give would be much appreciated
thanks
Lee
(Just for background information )
One of these grinds may be going into a new motor i'm building for my 7/11 . The basic specs of the new motor are - 1340 cc big block running 12:1 ( ish ! ) Compression , flowed head with big inlet & ex valves , RS38's & yoshi duplex system .Use will be mainly fast road with the odd foray up the 1/4 mile.
UK lee is offline
post #2 of 6 (permalink) Old 02-29-2004, 10:59 AM
Has been Texan longer than the cheerleader
GixxerRacer371's Avatar
Motorcycle: Son's 04 GSXR 600
Re: Cammotion / Yoshimura Cam Specs ?
Only specs in the old Yoshi catalog are as follows......
SUXR162
Intake Lift: 10.0
Intake Duration: 252
Exhaust Lift: 8.5
Exhaust Duration: 245
GixxerRacer371 is offline
post #3 of 6 (permalink) Old 02-29-2004, 11:32 AM
pan'86's Avatar
Motorcycle: push a 96 1100
try this link
CAMS PAGE
pan'86 is offline
post #4 of 6 (permalink) Old 03-01-2004, 12:48 AM Thread Starter
UK lee's Avatar
Thanks for your input so far dudes .
Ok then , I've managed to establish (most) of the specs of these two cams
Cammotion G21x 0.380" Lift 250° Duration 110°LCA 15/55°/55°/15° timing
Yoshimura SUXR162 INLET 0.393" Lift 252°Duration
Yoshimura SUXR162 EXHAUST 0.335" Lift 245° Duration
My first question is , Like this Cammotion grind , All the other aftermarket cams I've seen ( Megacycle / Kent / Piper / Web etc ) almost always use the same profile & lift for both IN & EX . The Yoshi ones use a different profile for IN & EX - much like the original Suzuki Ones. What advantages / disadvantages are there to this ? Is there any reasoning behind it .
Secondly the exhaust profile of the Yoshi Stg 2 cams is virtually the same as the stock cam from an '88 750 , but the inlet is significantly 'hotter' , with even more lift than the G21x . Again , What advantages / disadvantages are there to this ? Is there any reasoning behind it ?.
I'd still like some feedback from anyone with any 'real world' experience of either of these grinds , and your opinions on which one would suit my particular application the 'best' .What are the 'characteristics' of these cams - what effect would they have on power & torque ?
Cheers guys
Lee
UK lee is offline
post #5 of 6 (permalink) Old 03-01-2004, 10:25 AM
Grandpa 88's Avatar
Motorcycle: 86 Gsxr 1100, 82 Katana 1000, 86 GSXR 750 LTD, 00 Harley Softail, 99 Yamaha R1
Be careful these cams like lots of RPMs.
Mike
Grandpa 88 is offline
post #6 of 6 (permalink) Old 03-01-2004, 10:27 AM
pan'86's Avatar
you would think the best one to ask about the cams my be gsxr12161216
i know milder intake and hotter exhaust would help torque and still help house power like putting just the exhaust cam in a bandit 12 motor
also differant profiles for intake and exhaust is good in a nitrous motor but i dont remember off hand why
pan'86 is offline
