91-92 BST40SS carb parts / rebuild kits - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 19 (permalink) Old 02-18-2010, 06:11 PM Thread Starter
Motorcycle: 91 GSXR 1100
Smile 91-92 BST40SS carb parts / rebuild kits
Hello fellow gixxers
First real post in the forum, i hope it isn't stupid... I've seen a few messages dealing with this topic, but didn't really get a definitive answer, so...
I recently joined the gixxer world, acquiring a 91 GSXR 1100 (picture). Great machine, but it's a little unstable in low RPM's. Also, when you twist the wrist a little, below 5000RPM's, it stalls for a while and then gets back to full power.
I believe there must be a few bad/dirty parts on the carb so i figured out i'd do a little cleaning/synching.
The problem is... it came with a set of Mikuni BST40SS carbs (Brazil got the european model), and i can't really get the OEM/Aftermarket spares from the US market since those are BST36SS' and the jets/needles are different.
So my only option, for jets and other stuff, is to acquire them from an European/Canadian dealer. Are there any known dealers i can order parts from?
For other simpler parts, doing a little search, i stumbled upon Keyster kits (K-584 i believe). Are these any good? Will they fit in the BST40SS'? Those are easier to order from an US shop.
Thanks in advance,
Luis
GSXR 1100 91 Black/Grey
freezehawk is offline
post #2 of 19 (permalink) Old 02-18-2010, 06:41 PM
BRYCE88's Avatar
Motorcycle: 88 GSXR 7/11
Re: 91-92 BST40SS carb parts / rebuild kits
WOW that thing looks new
BRYCE88 is offline
post #3 of 19 (permalink) Old 02-18-2010, 07:07 PM
Motorcycle: mike91 1216
I am in canada...what exactly do you want? i can price it from my dealer,and send it to you...post here or PM me....
mike
mike91 1216 is offline
post #4 of 19 (permalink) Old 02-18-2010, 07:49 PM
Umm, which side goes down
From the US you can go to http://www.carbparts.com/mikuni/street.htm they have the RS parts in stock. Most likely a good cleaning, a bench sync and setting the accel pump should fix most of you woes. Nice bike.
oldboy is offline
post #5 of 19 (permalink) Old 02-18-2010, 07:52 PM Thread Starter
Thanks Bryce, the bike is in good shape. The previous owner didn't ride it that often.
Mike, really appreciate the help... I'm thinking about 4 kits of the 40mm-specific parts, which are the following... Not sure if all those are shot, but it's good to have them handy anyway.
  • 09491-25010 - Main Jet (125)
  • 09494-00721 - Jet Needle (P-2)
  • 09493-24007 - Jet Air (1.2mm)
  • 13383-41C00 - Needle, Jet (6zd13-3)
  • 09492-40014 - Jet Pilot (#40)
  • 13279-47070 - Screw Air (2.0)
  • 13370-07D00 - Valve assy needle (don't really need this if the Keyster kit is good quality and fits the BST40SS')
Do you have any recommendation of carb repair/gasket kits you use in your bike?
Regards,
Luis
post #6 of 19 (permalink) Old 02-18-2010, 07:53 PM
Intguy's Avatar
Motorcycle: 1997 ZX11 Ninja
Very nice, still has the warning stickers on it LOL.
cheers
Intguy is offline
post #7 of 19 (permalink) Old 02-18-2010, 08:02 PM Thread Starter
Thanks for the tip! I had visited that site before from a link in the forum, but didn't find the BST40-specific parts i needed, probably because i couldn't figure out the part numbers and codes... :-(
Out of curiosity, when people talk about RS carbs, are those the same as BST's?
I'm just new to the whole carb model business... :-)
post #8 of 19 (permalink) Old 02-18-2010, 08:13 PM
jdmcb3si's Avatar
Motorcycle: 1992 gsxr 750
yes the bst/rs carbs are the same. The CV carbs are the different ones.
jdmcb3si is offline
post #9 of 19 (permalink) Old 02-18-2010, 08:36 PM
40 bst carbs are a oem factory cv carb they are totally different than a mikuni rs flatslide....
so any rs parts will not work...
gimme a day or2 and ill send you the pricing... 4 of each correct
post #10 of 19 (permalink) Old 02-18-2010, 09:02 PM
Superstock
gotgixers's Avatar
Motorcycle: 1986 GSXR 7/12
what he^^^^ said is correct. BST's are factory Mikuni CV's. While RS's are Mikuni flatslide carbs. And the parts do not interchange...
gotgixers is offline
post #11 of 19 (permalink) Old 02-18-2010, 09:20 PM Thread Starter
Hum, OK. So the BST's are more like "semi" flat (one flat side, the other side is round), whereas RS' would be "full" flat slides, is that right?
As for the pricing, no hurry. Whenever you have them, let me know... 4 of each indeed.
post #12 of 19 (permalink) Old 02-19-2010, 03:48 AM
Motorcycle: 1986 GSXR750
Sort of,
BST's are a CV (constant velocity) type that have one slide vacuum controlled (front one) and the round butterflies directly controlled by your throttle. It's done to make a smooth ride, with the vacuum opening the slide in a linear smooth fashion. Downside is has more parts in the way of airflow size for size with a flatslide carb (flows a bit less).
Flatslides just have a single slide that's controlled by your throttle, so if you whip them open hard in the wrong gear they will probably just bog down - they require more finesse with the right hand, often have dual push pull cables with a heavier feel than CV's use more gas but are faster in skilled hands.
they work in pretty different ways to get the same job done.
FruitLooPs is offline
post #13 of 19 (permalink) Old 02-19-2010, 05:49 AM
The differentce in the RS carbs are the bodies and what needles are used, CPW has a list of the basic builds and the diagram of the carbs will get you the part numbers.
oldboy is offline
post #14 of 19 (permalink) Old 02-19-2010, 10:21 AM
Ghostrider
ghostrider.1127's Avatar
Motorcycle: few gsx-r
change only emulsion tube and needles
your bike change totally
replace the jets are most of the time ,just waste money
(emulsion tube for 1127 91-92 engine one of the really big problem)
ghostrider.1127 is offline
post #15 of 19 (permalink) Old 02-19-2010, 11:34 AM
Superstock
gotgixers's Avatar
Originally Posted by FruitLooPs View Post
Sort of,
Very well said ....
post #16 of 19 (permalink) Old 02-19-2010, 06:34 PM
MrHotrod's Avatar
Motorcycle: ,1989 FZR600,88YSR200
Doesn't factory pro sell kits for these carbs?
MrHotrod is offline
post #17 of 19 (permalink) Old 02-19-2010, 10:06 PM
Superstock
gotgixers's Avatar
I believe they do....
post #18 of 19 (permalink) Old 03-09-2010, 09:13 PM Thread Starter
Looking through the factory pro site, they do have a 40mm kit. Looks like they even have the emulsion tubes made according to the stock specs... Nice!
Mike, did you have a chance to get those prices?
Thanks,
Hawk
post #19 of 19 (permalink) Old 03-09-2010, 10:55 PM
91 Gixxer's Avatar
Hey Freezehawk, I'm not mechanical at all so I can't help on your question... but did at least want to chime in and say nice freakin bike! That really looks awesome!
Cheers.
91 Gixxer is offline
