r1/r6 shock fits a slabby???? - Page 3 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #41 of 70 (permalink) Old 04-24-2010, 02:04 PM
Motorcycle: micron boy
Re: r1/r6 shock fits a slabby????
That looks great Tony, did you have the same issues? How's the bike feel now? Is it stiff enough? some say it needs a stiffer spring? thanks
micron boy is offline
post #42 of 70 (permalink) Old 04-25-2010, 02:21 AM
GSXR Tony's Avatar
Motorcycle: 1986 GSXR 750
Originally Posted by micron boy View Post
Just thought i'd re-awake this thread as i've got an R1 04-06 shock. It's just out of alignment at the top & just touches the knuckle on my 86 750, is this normal?
YES! this is normal- exactly how mine used to fit-
Now I put in a 1100 swing arm, and the 1100 lower pivot arm and the R1 shock is WAYYYYYYYYYYY too long, wont fit in a million yrs-
Don't know what I'm gunna do because I really like the shock?????
GSXR Tony is offline
post #43 of 70 (permalink) Old 04-25-2010, 09:00 AM
Keep the 750 arm and swinger!
post #44 of 70 (permalink) Old 07-26-2011, 09:32 PM
Motorcycle: 1986 GSXR1100
Ok it's been well over a year since anyone has commented on this thread. I did a search and it seems most people are doing this swap to a 750. I have an 86 1100. Ghostrider posted that the R1 shock is 300mm long vs the original 86 1100 is 315mm. I am looking to increase ride height not lose any. I also saw that the cbr600rr shock may work, but what is the length of that? The R1's molded reservoir is the least intrusive to the battery box I can see. All the GSXR1000 have a different mount at the bottom of the shock so no shaving it down to fit.
Any other ideas? I need to know lenghts as well with the other ideas.
Thanks,
Dave
davereed is offline
post #45 of 70 (permalink) Old 07-27-2011, 04:10 AM
Motorcycle: 1990 GSXR 1100
Thanks,
Dave
Here you go Dave , this might help.... according to the chart and your measurements, there are quite a few Suzuki options as well as Honda options. I personally would go with a Honda 1000rr unit as the spring rate is over 12kg/mm and has more positive adjust-ability. The adjustment collar is also more user friendly. If you want to go about an inch higher , go with a GSXR 750 shock as it has a longer stroke.
ANDRASTA is offline
post #46 of 70 (permalink) Old 07-27-2011, 11:29 AM
Yeah but I am looking for an easy swap. I looked at all the gsxr shocks and it seems the only one that doesn't have a fork like attachment is the 2009 1k. I will look at that chart and search eBay for pics so I can figure out mounting options. Thanks
davereed is offline
post #47 of 70 (permalink) Old 07-27-2011, 01:10 PM
By the way I noticed that the Ohlins catalog lists a lot of shock lengths if any needs it.
davereed is offline
post #48 of 70 (permalink) Old 12-07-2012, 02:21 AM
Motorcycle: GSXR 1000K2, GSV 250, GSXR 750 85
This is a great thread I will be doing the R6 shock changover soon
JustmyGixer is offline
post #49 of 70 (permalink) Old 05-20-2015, 08:56 AM
Tonemaster's Avatar
Motorcycle: 85 Gixxer 7/11
Which adjuster on the R1 shock is comp and which is rebound??
Tonemaster is offline
post #50 of 70 (permalink) Old 05-22-2015, 08:10 AM
The other OG
old gsxr's Avatar
gggooggall it
old gsxr is offline
post #51 of 70 (permalink) Old 05-23-2015, 01:51 PM
Tonemaster's Avatar
I just did the swap, and my shock had way more to go than in this pic! I ha a good 3/4" to compress to get the bolt in. Had to use a jack. I must have an 1100 arm on my bike. I know it came with 1100 rims, brake, front end, but a 750 frame. How can you tell the diff between the two swingarms?
T.
post #52 of 70 (permalink) Old 05-27-2015, 01:10 PM
Tonemaster's Avatar
hmm,,,ok
post #53 of 70 (permalink) Old 05-27-2015, 05:57 PM
awasson's Avatar
Motorcycle: 1985 GSXR 750, 1986 GSXR Limited, GSXR750RK (in restoration mode), 1973 GT-750 (no longer have, looking for another)
Someone else knows I'm quite sure... This is what a quick scan of the interchange sticky came up with: http://www.gixxer.com/forums/showthr...rm#post5616950
Maybe start another discussion called:
"what's the difference between a 1st gen 750 swing arm and a 1st gen 1100 swing arm?"
awasson is offline
post #54 of 70 (permalink) Old 05-29-2015, 11:16 AM
I searched and the only thing I could find is the the 1100 swingarm is about 4cm longer than the 750 swingarm. I couldn't readily find the exact lengths of each though.
Rayobot is offline
post #55 of 70 (permalink) Old 05-30-2015, 04:52 PM
Oiler Mod
long_av8r's Avatar
Motorcycle: (3) 1st gen 750's; (2) 1st gen 1100's; 90 7/11; 05 RMZ-450; 83 Honda CB1000C; 78 Yamaha DT 175E; 89 HD 883 Sporty; 98 KX250; 85 ATC 125M; 04 Polaris Predator 500; and a few kids quads.
Actually, its pretty easy to tell them apart by looking at the point where the linkage attaches - and for that matter the linkage itself. The 750 linkage is smaller, has a smaller center bearing and does not have the cast in recesses like the 1100 link. As far as the arms go, the 1100 has a far more robust linkage area, is made up entirely of extrusions, and has a flat plate with 3 holes in it in the linkage area. The 750 arm is manufactured from castings and extrusions, and the linkage point is flat aluminum plate.
I'm sure if you do a google search you can find photos of both. If not, search ebay.
I'm with the government - I'm here to help.
long_av8r is offline
post #56 of 70 (permalink) Old 11-14-2015, 09:04 AM
Sacs's Avatar
Motorcycle: Gixxers from '85 to '91
Please, i need your help to fit a 2002 R6 shock in my 85..lower mount cut, how do you compress the shock to align the mounting holes??Bottom bolt is in but upper is a bit high... i have no spring tools so need a trick!
Sacs is offline
post #57 of 70 (permalink) Old 11-14-2015, 02:10 PM
Tonemaster's Avatar
I used a small scissors jack between the upper rails and the top of the shock with a piece of wood between the shock and jack. Then used a punch to guide the eyelet in place and slide the bolt in.
T.
awasson likes this.
post #58 of 70 (permalink) Old 11-15-2015, 01:38 AM
Sacs's Avatar
T.
Great!! this thing was turning me mad..i'll try this way, thanks a lot for your help
Sacs is offline
post #59 of 70 (permalink) Old 11-15-2015, 04:14 AM
fok
fok's Avatar
Motorcycle: Too many / Not enough
Are you guys doing this mod based on cost? I'm not sure I get it......
Why not change the shock to one that's right for the bike, it's use and the rider's weight? There are plenty of quality manufacturers out there who'd make a shock the right length and with the correct damping and spring rates.
Do shocks from other bikes really work that well?
fok is offline
post #60 of 70 (permalink) Old 11-15-2015, 09:34 AM
Motorcycle: 1988 GSXR 7/11
I think this mod is done because the shock is plentiful and reasonably priced. Try and find an Ohlins for an oil cooled and be prepared to fall over at the price.
I personally would love to put a BMW shock on mine, but honestly I doubt I would feel the difference. That's just due to my limited rime on my bike though.
My bike is such a Frankenstein that I have no idea what shock is on it or if it's set up right. For my bike, 1988 750 Canadian, I believe that the shock should have an external reservoir but it doesn't. Even the 91 rear end it came with should have an external reservoir. I dunno.
Maybe after riding it next year more often I will figure out if I should do a swap.
Guzman is offline
