How can you tell when your bike is running too lean or too - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 17 (permalink) Old 02-15-2006, 09:33 AM Thread Starter
alex_howard_2001's Avatar
Motorcycle: alex_howard_2001
How can you tell when your bike is running too lean or too rich?
alex_howard_2001 is offline
post #2 of 17 (permalink) Old 02-15-2006, 03:18 PM
Re: How can you tell when your bike is running too lean or too
Check your spark plugs...if they are "sooty" black, you're rich, if it's white you're too lean, should be a nice tan color. If everything is working properly on the fuel injected bikes it should be pretty close, maybe a little on the lean side...best bet is to take it to a dyno and get your air/fuel graph...this will tell you everything...
gsxr_rider is offline
post #3 of 17 (permalink) Old 02-15-2006, 03:32 PM
icycold's Avatar
Motorcycle: GSXR1000 K6 & RGV250 SP
Plugs are a good reading but you have to run your bike hard for at least 8-10minutes before you get a descent reading.
icycold is offline
post #4 of 17 (permalink) Old 02-16-2006, 01:24 AM
Super Moderator
RussZTT's Avatar
Motorcycle: 2003 Copper and Black 1000
Also look inside the tip of your pipe. If its thick black or alot of it, its on the rich side. Its there isn't much or any at all or a white tent, its running on the lean side. Generally bikes run fine from the factory unless you modded the bike with a map.
RussZTT is offline
post #5 of 17 (permalink) Old 02-16-2006, 01:48 AM
Superbike
JetSpeedz's Avatar
Motorcycle: GSXR's
they run rich from factory and like they said check the plugs easy idicator
JetSpeedz is offline
post #6 of 17 (permalink) Old 02-16-2006, 02:16 AM
Pipe-laying Admin...
Anthony D's Avatar
take it to a dyno that monitors a/f ration, and go from there. imo, it is well worth the money to find out how your motor is doing.
Anthony D is offline
post #7 of 17 (permalink) Old 02-16-2006, 02:16 AM
Anthony D's Avatar
take it to a dyno that monitors a/f ratio, and go from there. imo, it is well worth the money to find out how your motor is doing.
post #8 of 17 (permalink) Old 02-16-2006, 02:16 AM
I got a bright blue tint to my pipe.
K600R is offline
post #9 of 17 (permalink) Old 02-16-2006, 09:38 AM
Supersport
.:1k:.'s Avatar
Motorcycle: 06 1000
What symptoms are you experiencing that would lead you to believe its a fuel delivery problem?
.:1k:. is offline
post #10 of 17 (permalink) Old 02-16-2006, 10:50 AM Thread Starter
Before I had motor work done, I was told my bike was running lean because I had it for less than 2 weeks and my pipe was deep blue too soon. So some guys I ride with said that my bike was running lean. Lee told me it was not when I took it to him. But I just want to know how to tell myself. My bike sounds a little different than other bikes with the stock can but I am assuming that is because of the motor work. I have not changed plugs since I bought the bike. So I figure its way past due.
post #11 of 17 (permalink) Old 02-16-2006, 11:38 AM
Super Moderator
RussZTT's Avatar
I had a dude tell my that my bike was running lean cause my Akra was turning blue. That just told me how little he know..
RussZTT is offline
post #12 of 17 (permalink) Old 02-16-2006, 12:11 PM
Kidder's Avatar
Motorcycle: 09 Buell 1125CR
I always thought bikes from the factory came on the lean side so they'd pass the emissions tests with no issues.
Kidder is offline
post #13 of 17 (permalink) Old 02-16-2006, 12:31 PM
Supersport
.:1k:.'s Avatar
Motorcycle: 06 1000
how old is the bike?
.:1k:. is offline
post #14 of 17 (permalink) Old 02-16-2006, 11:28 PM Thread Starter
I have the '03 zuk1k
post #15 of 17 (permalink) Old 02-17-2006, 05:54 AM
Super Moderator
RussZTT's Avatar
What is all done to the bike. Do you have the PClll on it?
RussZTT is offline
post #16 of 17 (permalink) Old 02-17-2006, 07:15 AM Thread Starter
stg3 kit,porting head-mod, valves-springs-cams-stacks-pair kit-cam chain tensioner, pcIII, custom map, TRE JSD switchable, -1front, stock exhaust (use to have hotbodies undertail , they dyno then was 170rwhp from Lee's and local dealer.)
post #17 of 17 (permalink) Old 02-17-2006, 08:35 AM
Anthony D's Avatar
the stock exhaust is probably causing some issues with all the mods you have, and not letting out enough exhaust gases. get the full system on there asap, and get it remapped.
