Steering stem nut socket - Page 2 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #21 of 22 (permalink) Old 12-11-2012, 01:44 PM
Re: Steering stem nut socket
Don't know why this is coming up after six years but you're right. The top nut is the same as the rear axle nut (36 mm). I got mine at OSH for around $3.50 when they cleared out some Craftsman sockets.
The lower spanner nuts need something different. Suzuki sells it for a bunch of money. Komotodraggin.com sells it for less. Turbosuzukis sells it for still less on ebay.uk. Or you can make one like this.
post #22 of 22 (permalink) Old 12-12-2012, 06:36 PM
Correct, the steering yoke nut is the same size "36mm" as your rear axle nut, you have a tool in your bikes tool kit for it. Note: it may be tight so you nay need a pipe extension for leverage
galahs is offline
