2008 hot stalling problem - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 13 (permalink) Old 07-09-2009, 10:00 AM Thread Starter
akillya's Avatar
Motorcycle: 2007 GSXR 750
I have a 2008 GSXR1000. When the bike is hot it always stalls once the RPMs are brought down to idle. When I refire the bike it will not idle, it keeps stalling. Any ideas?
akillya is offline
post #2 of 13 (permalink) Old 07-09-2009, 10:20 AM
Lets go racing!
Chugs's Avatar
Re: 2008 hot stalling problem
Do u run a power commander or engine management? I've had problems on hot days as well, fires right up if I take off my yosh ems.
Chugs is offline
post #3 of 13 (permalink) Old 07-09-2009, 10:37 AM Thread Starter
akillya's Avatar
No I am not running a Power Commander or a Yosh EMS.
akillya is offline
post #4 of 13 (permalink) Old 07-09-2009, 02:25 PM
Not really old,just Vintage
oldfart01's Avatar
I have a PCIII & full exhaust, never had an issue even once with idling.
oldfart01 is offline
post #5 of 13 (permalink) Old 07-09-2009, 02:46 PM
Motorcycle: GSXR-1000 K8 (BR)
Is your bike stock? You usually get that when your lambda sensor is working bad (thats on a car) which fucks up the ECU.
If you want failing when rolling its not the injectors or anything else... anyway does your FI light comes up? You may have a leak anywhere?
Hope someone can help you better.
brunobenchimol is offline
post #6 of 13 (permalink) Old 07-09-2009, 04:25 PM
TVONE2's Avatar
Motorcycle: 2007 GSXR1000 '94 FZR1000
sounds like the ISC (idle speed control) valve is hung up.. or bad.
TVONE2 is offline
post #7 of 13 (permalink) Old 07-09-2009, 07:46 PM
Pretty sure the 2008's had the ISC recall done to them already.
What is your idle set at?
Should be set around 1250-1500. If it's set too low it can randomly die.
SPL170db is offline
post #8 of 13 (permalink) Old 07-09-2009, 08:04 PM
On hiatus...
Anthony D's Avatar
+1 on your idle being too low. should be around 1,300rpm when the bike is at operating temps.
Anthony D is offline
post #9 of 13 (permalink) Old 07-10-2009, 12:09 AM
Motorcycle: K8 750 B/W
ask the service dept.
aussie lee is offline
post #10 of 13 (permalink) Old 07-10-2009, 09:43 AM Thread Starter
akillya's Avatar
I already adjusted the idle up so I know its not that but it did improve the situation. I suspect it is the ISC valve so I may just plug it and reset the idle down.
akillya is offline
post #11 of 13 (permalink) Old 07-10-2009, 02:58 PM
d3coy's Avatar
Motorcycle: 76" Black/Orange GSX-R 1000 K7
are your spark plugs good? do you run a lot of race gas? the reason i ask is because some types of race gas can cause fueling problems if left in the tank for extended periods. also, how "hot" is your bike when you encounter the problem? i know if it creeps up around 200F the bike pulls timing, which makes the rpms fluctuate irregularly.
d3coy is offline
post #12 of 13 (permalink) Old 07-10-2009, 03:18 PM
Bobthebutcha's Avatar
You have a vacuum leak. Look for cracks, loose/missing connections hoses etc.....
Bobthebutcha is offline
post #13 of 13 (permalink) Old 07-13-2009, 01:23 AM Thread Starter
akillya's Avatar
Checked for vacuum leaks, found none so I guess I will test the ISC valve operation via the manual.
akillya is offline
