GSX-R1000 Performance Questions Here! - Page 51 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1001 of 1103 (permalink) Old 10-10-2012, 09:30 PM
GSXRAssassin's Avatar
Re: GSX-R1000 Performance Questions Here!
K5 is done- 1070cc, light/balanced crank, ported head, Web cams, TRE, BMC, Ti-Force, V-Stacks, serious dyno time. Very happy with it. Now I want to build a K9. Do the same tricks work on the newer engine? If not, where should I start to ultimately achieve 200+ rwhp? Thanks.
GSXRAssassin is offline
post #1002 of 1103 (permalink) Old 10-10-2012, 10:18 PM
Function over F0RM
performula's Avatar
Motorcycle: L2 GSXR1
Bro, just buy a ZX10R and be done with it. I hear it can kill unicorns, fairies, and shit.
Z-Bomb = 210mph
performula is offline
post #1003 of 1103 (permalink) Old 10-11-2012, 10:26 AM
Suzuki until the end bro. True, the ZX10R is a dragon slayer but I want to turn a K9 into a dragon slayer slayer.
post #1004 of 1103 (permalink) Old 10-11-2012, 10:31 AM
Motorcycle: K6 and a xz12r
Those tricks will do it.... I think that a good epoxy head work, a set of cams, filter, exhaust and a bazzaz full will do it.
mpp12 is offline
post #1005 of 1103 (permalink) Old 10-12-2012, 01:43 PM
It looks like the largest big-bore kit for the K9+ is 1039cc (If anyone has seen bigger let me know). If I do that plus some good top end work (head & cams) I might be able to get some good ponies out of this thing.
Q: With some of the oiling going through the crankshaft has anyone dared to stroke or lighten/balance the crank? If so, any word of complications? The light/bal crank onmy K5 feels great and I want to do the same thing on this project. Thanks.
GSXR
post #1006 of 1103 (permalink) Old 10-13-2012, 04:40 PM
Balance it by all means but why lighten it? Most modern engines really need the inertia of the crank as BMW found out early on.
Mike Edwards is offline
post #1007 of 1103 (permalink) Old 10-13-2012, 04:54 PM
JP1143's Avatar
Motorcycle: K4 1143, L2 1K
So true..... you develop more tq without it lightened.
JP1143 is offline
post #1008 of 1103 (permalink) Old 10-14-2012, 04:46 PM
macka's Avatar
Motorcycle: 09 gsxr1000
We use complete cartridge replacements on all the BPF's....just take the entire guts out of it and replace it.
The 05-08 forks are basicly the same...[/QUOhi
ive got an 091000 with BPFs forks, question? are the gold valves worth upgrading too with ohlin springs, or can i use 06-08 forks im 170lbs im just trying to find better grip on the side of the tyre i use k1 meztlers, and i dont want track type set up as its not a race bike has anyone done a good mod on these?
macka is offline
post #1009 of 1103 (permalink) Old 10-14-2012, 05:35 PM
the 07 has better rebound than the 05 ones, I did it and was night and day diference betwen those 2
mpp12 is offline
post #1010 of 1103 (permalink) Old 10-14-2012, 07:55 PM
K6trackday's Avatar
Anyone know who sells Yosh Kit parts for k6 1000? More specifically midpipe for the 4-1 full system (The system that uses the offset oilpan)? Every place ive emailed has ignored me...
Also talking performance, what exhaust was best in your experiences for the K6 with head work, yosh cams, em pro etc etc?
K6trackday is offline
post #1011 of 1103 (permalink) Old 10-14-2012, 08:06 PM
Arata, Acro, Leo.... if on a budget Arrow.
mpp12 is offline
post #1012 of 1103 (permalink) Old 10-14-2012, 08:25 PM
macka's Avatar
so what are you suggesting for my 09?
macka is offline
post #1013 of 1103 (permalink) Old 10-15-2012, 07:16 AM
If the stock components of the 09 are not up to your skills, then ask some team to see what they are using in superstock.
mpp12 is offline
post #1014 of 1103 (permalink) Old 10-15-2012, 04:11 PM
macka's Avatar
has anyone made improvements their showa BPF valves or spring changes for the road has it been good or not?
macka is offline
post #1015 of 1103 (permalink) Old 10-24-2012, 12:18 PM
I really like the spin-up of the motor. The acceleration is nasty. I even get a kick out of the deceleration.
It feels like the motor revs with less effort. No doubt it doesn't have the same low end "punch" but I like the higher rev stuff anyway. Going from the South course to the North course at Autobahn (long connecting straight) the thing just screams!
GSXR
post #1016 of 1103 (permalink) Old 10-27-2012, 12:11 PM
JP1143's Avatar
It feels like the motor revs with less effort..... but I like the higher rev stuff anyway. the thing just screams!
GSXR
Gotcha
JP1143 is offline
post #1017 of 1103 (permalink) Old 11-16-2012, 07:17 PM
vonmartin1's Avatar
Chip im a suzuki men from top to bottom do u thing they are getting a little left behind with the BMW and ZX10 advancements or is something good coming..
vonmartin1 is offline
post #1018 of 1103 (permalink) Old 03-01-2013, 01:58 AM
Non-Giver of F*ucks
Xrated_Gsxr's Avatar
Motorcycle: 02 gsxr 600/1k engine
is there a way to upgrade your fuel injectors from one hole on the 01-04 gsxr 1000 to a 4 hole injector like on the 05 and up?
also is it better to swap the head of a 05-06 gsxr 1000 complete or just to do the intake swap with adjustable sprockets on the 04 gsxr 1000 engine?
Xrated_Gsxr is offline
post #1019 of 1103 (permalink) Old 03-04-2013, 02:06 PM
Squid 2001 GSXR1000 k1
alant's Avatar
Motorcycle: 2001 GSXR 1000 k1
Chip - I have a lightened crank (ex-APE) with 76mm Wiseco pistons 13.5:1 CR with Carpenter cams on adjustable APE cam sprockets:
Intake .397" lift, 248deg of duration at 0.040" with
Exhaust .350" lift, 244deg of duration at 0.040"
It seems the cost of porting by CNC/other is around $1000 give or take, but the porting alone returns around 5hp approx. So if I do my own hand porting & do the "standard" clean-up the return on $$ may be better value if the result is even 2 to 3hp.
Would you agree with this or would you advise a CNC porting job? Is it worth $1000 for the extra 3hp for just a weekend track bike?
alant is offline
post #1020 of 1103 (permalink) Old 04-12-2013, 07:48 PM
Motorcycle: 03 Bandit 1200& 06 gsxr 1000 racer
Hi Chip with this statement=Pair valve mod where you rout the crankcase vent up to the ports in the valve cover and inject he crank case pressure back into the exhaust. The venturi effect can actually pull air out causing a negative pressure in the crank case. Thus....hp. When routing this to the valves do you separate and run them to both or can I run it to just one on the 05-06 1000. And how do you inject the crank C pressure back into the exhaust (sorry I dont understand).
My second quest. is im going to be running a mild ported head with stock pistons and would you recommend a slightly thinner head gasket? For cam timing im putting adjustable sprockets on, im a fat boy racer at 260lbs I'll be racing at Topeka- Brainerd- and Road America I think what I want is more midrande right what would work for me for cam timing? Ill be running non oxygenated 91+ pump gas. I now Brainerd and R.A. are longer tracks but with my weight would the midrandge help me more and this is on my 06 1000? Thank for all the insight on this hole thread you rock thank you for posting this!!!
CRA#98 is offline
