09 gsxr 750. Start up problems only 4k miles! - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 9 (permalink) Old 03-08-2012, 02:51 AM Thread Starter
Recks's Avatar
Motorcycle: k9 2009 Gsxr750..Blue/white/black
Unhappy 09 gsxr 750. Start up problems only 4k miles!
Hello everyone,
So today. I had issues starting my bike after school bike was sitting outside for roughly 12 hours ( yeah long school day) . Wen I finally when to the bike to turn it on it had a rough idle and would not stay on. I had to gas it a little during start up to keep the bike on to warm up. I smelled rich So I let go of the throttle and it died again. I am slightly confused on what could be causing this problem? When I finally got her home I turned her off and turned it back in and she turned on like a champ.. My bike only had 4k miles on it. And have only had her for a year or so. Bought her new in 2010.
Was it because it is cold outside? Slightly?
The only mods I have on my bike are HID's low and high beam.and a Jardine slip
on. I've seen a lot of you guys have the same high and low beam HID's did you guys have similar problem?
Thanks for any feed back.
riding 09 gsxr750.. and dont know what to do to it just yet...
besides ride...anyone on here from north bay who wants to ride?
Recks is offline
post #2 of 9 (permalink) Old 03-08-2012, 01:29 PM
rraiderr's Avatar
Motorcycle: Stretched and slammed Busa
Re: 09 gsxr 750. Start up problems only 4k miles!
Welcome to the club.
http://www.gixxer.com/forums/showthread.php?t=301833
rraiderr is offline
post #3 of 9 (permalink) Old 03-08-2012, 05:32 PM Thread Starter
Recks's Avatar
dammit..
Recks is offline
post #4 of 9 (permalink) Old 03-08-2012, 05:41 PM
Moose Knuckle Racing!
Driving_Miss_Daisy's Avatar
Motorcycle: GSXR750k8
You do have a E-33 bike. Disable that function. I had to on my bike because liquid gas got into the lines and jacked that whole system. When this happens the bike runs extremely rich and won't stay started cold or hot. If this is so, E-33 is your problem.
Driving_Miss_Daisy is offline
post #5 of 9 (permalink) Old 03-08-2012, 06:14 PM Thread Starter
Recks's Avatar
e-33? How would I do this? And my bike stays on after 100 degree's...
Recks is offline
post #6 of 9 (permalink) Old 03-08-2012, 06:55 PM
If you bike was purchased it Cali, it has the E-33 option. Lamons terms smog crap.
This is hard to explain. Easy to do but hard to elplain.
There is a hose that goes from tank to a check valve, in front of the battery. Remove that hose and block off the tank connection. From that check valve a hose runs up past the battery to a charcol canister in the rear passenger fender. Remove that hose. Just leave the check valve there with nothing hooked up to it. Remove that canister. Remove the other hose that goes from the canister to a check valve next to the throttle bodies. That is pretty much all you have to do.
This caused starting issues with me. I filled up my tank in 30 degree weather. Took my bike to work and with the heat from the engine the gas expanded and flooded my check valves and canister. None E-33 bikes would just leak that gas to the ground. So everytime I started the bike after that day the system was trying to get rid of the gas and was flooding the enigne. I removed all hoses and canister and let the bike run for 5 minutes holding the rpm up around 4k to get rid of the left over gas in the throttle bodies area. Bike ran perfetly fine after doing this.
Page 1B-6 in the service manual.
Stephen
K8 750
Free School for you Iraq Veterans
post #7 of 9 (permalink) Old 03-09-2012, 01:38 AM Thread Starter
Recks's Avatar
thanks i am going to try this this weekend.
Recks is offline
post #8 of 9 (permalink) Old 03-09-2012, 01:50 AM Thread Starter
Recks's Avatar
any videos showing this? just want to make sure i do it correctly
Recks is offline
post #9 of 9 (permalink) Old 03-09-2012, 10:35 AM
Nope. I am the only one that I know of that has done this.
Download the service manual. It has tons of drawings about it.
