Chain adjustment - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 17 (permalink) Old 09-24-2009, 09:33 PM Thread Starter
Chain adjustment
Hey quick question,
I want to adjust my chain and after adjusting the chain to 30mm slack, the chain tightens when I torque the axle nut back on.
So is it normal for the chain to get tighter after putting the axle nut on?
thx in advance.
Monochrome is offline
post #2 of 17 (permalink) Old 09-24-2009, 10:21 PM
F. Richard Head's Avatar
Motorcycle: 2003 GSXR 750
Re: Chain adjustment
Yes.
When you torque the axle nut, you're pinching the swingarm onto the axle spacers. This narrows it slightly and moves the wheel back ever so slightly.
You need to compensate for that in your initial adjustment such that you get the specified slack after the nut is torqued. It can take some trial and error.
F. Richard Head is offline
post #3 of 17 (permalink) Old 09-24-2009, 10:52 PM
Supersport
Speedin4fun's Avatar
Motorcycle: 2007 GSX-R 600
Set the slack where u need it with the adjuster screws...Then take a small wrench (or any other small tool) and put it in one of the teeth in the sprocket spin the wheel so its wedged in the chain (carefully) and tighten axle nut. When axle is tight spin the wheel to free the tool and whallah propper slack. It works and if done carefully it does not damage the sprocket or chain..
Speedin4fun is offline
post #4 of 17 (permalink) Old 09-24-2009, 10:56 PM Thread Starter
O thanks Richard head
post #5 of 17 (permalink) Old 09-24-2009, 10:58 PM Thread Starter
haha yea I just foud the video that showed that. I gotta get a freaking bike stand it would be much easier
post #6 of 17 (permalink) Old 09-24-2009, 11:08 PM
Supporting Vendor
MotoMummy's Avatar
Motorcycle: Mummy Bike
Easy way is to flip the axle so the nut is on the right side of the bike. then you when you tighten it you press into the adjusters and not away makes the job much easier...
MotoMummy is offline
post #7 of 17 (permalink) Old 09-25-2009, 12:01 AM
Moose Knuckle Racing!
Driving_Miss_Daisy's Avatar
Motorcycle: GSXR750k8
Damn great idea. I am going to do that next time I clean my chain.
Driving_Miss_Daisy is offline
post #8 of 17 (permalink) Old 09-25-2009, 05:09 AM
Lets go racing!
Chugs's Avatar
+1000 on flipping axle
Chugs is offline
post #9 of 17 (permalink) Old 09-26-2009, 03:19 PM
mz3onturn7's Avatar
Motorcycle: 08 gsxr 600
I have spent some time experimenting with the chain and the adjustments. I found the same problem with the axle nut but it can be worked around using the methods above. I also found that measuring the chain slack is not exact. 20mm – 30mm is not a large tolerance to work with. The chain has some stretch to it and depending on how hard you push it upwards you may have a difficult time getting an exact measurement.
I spent about 3hrs. Playing with it, using a measuring tape to find the centre of the chain and a measuring square to measure the chain slack at different points on the chain.
I got everything square and even, torqued to spec with approximately 20mm slack on the chain at the tightest point. I would have liked it to be a little looser but that was the best I could do while squaring the axle sliders symmetrically.
I did find that with the chain a bit tighter the shift from neutral to first while stopped does not clunk as hard.
mz3onturn7 is offline
post #10 of 17 (permalink) Old 09-26-2009, 05:37 PM
Mugen's Avatar
To my mind 20 mm of slack is not enough.
Take in to consideration that you haven't added yours and gear weight. I saw some video and a mechanic said that it's better to be a tad on the loose side than tight.
Mugen is offline
post #11 of 17 (permalink) Old 09-26-2009, 05:52 PM
Supporting Vendor
MotoMummy's Avatar
anywhere in the oem specs and you should be fine. I try to put mine on the looser side of that, but still in oem specs. unless you change your suspension, swingarm, etc then things change and the oem specs may not be correct for your application any longer. Just something to remember.
post #12 of 17 (permalink) Old 09-27-2009, 11:26 AM
The Dreaded Midnight Taint Slapper
grtfast's Avatar
Motorcycle: 2007 CRF250R
that is putting stress on the countershaft bearing.... you can do the procedure correctly without ever having to do that.
grtfast is offline
post #13 of 17 (permalink) Old 09-27-2009, 11:27 AM
grtfast's Avatar
correct.
a tad on the loose side may produce some "slap" noise, and slightly faster sprocket wear, but to tight can cause bearing damage, and also cause accelerated chain stretch from excessive heat.
grtfast is offline
post #14 of 17 (permalink) Old 10-15-2009, 02:57 AM
Dencho's Avatar
Motorcycle: 1998 GSX-R 750 SRAD (SOLD)
^ +1000 Never over tighten the chain. Thats a big
Dencho is offline
post #15 of 17 (permalink) Old 10-15-2009, 05:44 PM
Motorcycle: 2008 GSX-R750, 2006 Kawasaki ZX-14
make sure you also double check the wheel alignment notches on both sides because while you retightening the wheel sometimes have the tendency to get cocked a little sideways.
08 GSX-R750 is offline
post #16 of 17 (permalink) Old 10-15-2009, 10:16 PM
iuhutch's Avatar
Motorcycle: 2009 Suzuki GSXR 1000
Dis is what I did
Also, use a torque wrench and tighten ever so lightly.
iuhutch is offline
post #17 of 17 (permalink) Old 06-09-2012, 01:01 PM
Sheer brilliance, flipping the axle!!
donlycan is offline
